I have the Garmin inReach (same tech, new plastic) and I think you should be fine for battery life. The device will keep tracking until you tell it to stop, or the battery runs out. Mine will start to chime at you if the battery is below 25%. You'll need to set up Spotwalla correctly too. I'm curious on why you aren't going to turn it off when you're at sleep?
