Hey does anyone know where I can get a decent 3/8 cut off valve?
H Hulletttribe Member Jan 15, 2020 #1 Jan 15, 2020 #1 Hey does anyone know where I can get a decent 3/8 cut off valve?
Marc11 Premier Member Jan 15, 2020 #2 Jan 15, 2020 #2 OCSParts MTLB-6 3/8" Brass Barb x Barb Ball Valve, Lead Free, 0.1875" ID https://www.amazon.com/dp/B072MZDND8/ref=cm_sw_r_other_apa_i_V97hEbVFBYF4S Really high quality valve.
H Hulletttribe Member Jan 15, 2020 #3 Jan 15, 2020 #3 Ok thanks the one I have is already leaking at the handle. It less than 100 miles on it. I even tried tightening it no good.
B Berchunis Member Jan 17, 2020 #4 Jan 17, 2020 #4 If you haven't already found the replacement cut off valve, do consider "Pingle" brand fuel shut off valve. IME, does not leak and rebuild part are available. Yes, Pingle is a bit expensive.
H Hulletttribe Member Jan 17, 2020 #5 Jan 17, 2020 #5 I actually have a couple of cut offs ordered. Tyvm
