Garmin inReach Satellite Communicator - Long-Term Review
DrNeo
Over the the last 7 months and ~30,000 miles, I have been using the using the Garmin inReach SE+ to document my attempt at riding every single highway in Minnesota. You can check out my progress here!
I have also used the device to document/certify an Eggsanity Silver, a Border 2 Border ride, plus the Piston Diversity series of rides. After all of those miles, I thought I’d share some feedback!
The device:
I have the inReach SE+ which is about the size of a “normal” handheld GPS unit. Gamin makes two different versions that have the same footprint. They also make a Mini version that’s about half the size of the SE+/Explorer. The difference between the SE and the Explorer is that my unit does not have any integrated maps. You just get a breadcrumb trail. This wasn’t important to me as I’m going to primarily be using this on my motorcycle, and not hiking. Because it connects via Bluetooth to my phone, I can always use Garmin’s free Earthmate app for topo maps if I decide to head off on foot.
The device came with a strap, manual, and charging cable.The device is rated as IPX7 water resistant, so it doesn’t mind getting rained on or going for a short swim. The screen is bright enough to see in direct sunlight and has buttons that are easy enough to use with gloves on.
The Home screen:
Initial Setup
Setup of both the device and the online account were simple, I didn’t even have to go outside for it to capture the required GPS signal! I opted for the “Freedom Recreation Plan,” which allows me to “pause” the subscription throughout the year if I’m not using it. I did a detailed write up of the pros/cons of each plan here. With all of the taxes and fees, it works out to $37.26 per month.
General Use
The Freedom Recreation Plan (FRP) sends up a location every 10 minutes, creating a breadcrumb trail. My inReach has a specific URL that is associated with my device, which I can send to anyone that would like to follow my progress. I can also choose to upload this to Facebook/Twitter/etc. The FRP also allows me to send and receive 3 different preset messages for free (as many times as I’d like too). I have chosen “Starting ride,” “Gas/Rest stop,” and “Ending ride” as my 3 presets. (I chose these presets because I was really only using the device to certify IBA rides.) You can change these preset messages easily on the app or the website. Each time I send a preset message, a small icon appears on my map on the location, plus an email gets sent to whomever I’d like (in this case, to my wife). Contained in the email are my current location, the preset message (Gas/Rest stop) and a link to the map page. The inReach also feeds my Spotwalla page, so I can submit documentation to the IBA easily.
The tracking screen:
My 3 preset messages:
The device's trip odometer that begins when start tracking
The inReach also allows you to send custom messages too. The on-device keyboard does take a while, but you can link up your phone (via Bluetooth) to the device and type faster. You can also use just your phone and the Garmin app to do just about everything (including triggering a SOS for help) without having to touch the device at all!
This gives you a peek at what the online map looks like. On the left is a recent track that I've highlighted.
I generally ride with the device in my tank bag or in my top case. Neither of the locations impede the device from sending info or location updates. I can actually push/pull messages from inside my finished, insulated garage.
I have updated the device several times, just use the included USB port and jump on Garmin’s website. You will need to update the device if you make any changes such as preset message info.
Emergency Use
Since the device operates outside of a cellular network, I can trigger emergency services nearly anywhere should the need arise. Luckily, I haven’t had the needed, but it is nice to know that I can.
Weather
You can actually use the device to pull weather data for your current location or other locations.
This is the "Basic" weather forecast
Phone App
You can access basically everything that is on the device right from your phone. Routes, maps, tracking on/off, messages (both preset and custom), digital compass, weather, history, triggering a SOS, it's all there. The maps are highly detailed and you can download multiple regions if you travel outside of North America.
Topo maps with a track visible (in blue)
Other App options
Battery life
Battery life has been amazing so far, generally I can get 3 days of 14 hours of riding out of the device before it drops below 20%. Under 20% the device will warn you that the battery is getting low and you should charge in case you need to trigger an emergency. A typical 16-hour SS1000 saw a drop of ~15-20%. Charging is easy as the device uses a micro USB cord. Garmin does have a powered RAM-compatible mount, but I haven’t found it necessary.
Why I chose the inReach over a Spot device:
When I purchased the inReach, Spot had yet to come out with their latest version that has the ability to connect to a phone to send/receive messages. Being able to use two-way messaging with first responders to relay information about the situation really sold me on the device over Spot. Being able to say who/what/where/how intense with emergency responders can save a lot time and possibly someone’s life. I have also heard some horror stories with Spot about responding (or lack there of) to emergencies.
Gripes
The device itself has been great and the service has been stellar so far too. The website has slowly gotten better as the months have dragged on. Originally I had a tough time loading the maps and clicking on other areas of the website would continually prompt me to change my password. I thought that it was my computer or my web browser, but I got the same thing on other devices. This seems to have resolved itself over the past 4 weeks or so. I’m sure there were some growing pains as inReach transitioned over to Garmin from Deloreme.
Thanks for reading! Feel free to ask any questions, I’ll do my best to answer them!
Brian Thorn
I use the powered mount on the bike so I never need to worry about the battery charge. Some folks will say that I should have the inReach on my person in case of an incident in which I'm separated from the bike, but I carry a PLB in my jacket pocket for that. I actually haven't looked at any of my maps on Garmin's site as I've only been concerned about how it shows on SpotWalla, so you've piqued my curiosity and I'm heading that way now.
Good review!
Good review!
I'd be interested in knowing which PLB you use and it's dimensions
John Cooper
Thanks for the extensive review.
I have about 200,000 miles on my inReach. The model made before Garmin took over. It's features are similar, BT, two-way communication, 3 presets. Over time the little machine has been dropped (at speed on the 15), run over, and used for days in the rain. It is mounted to the powered cradle.
1. The cover on the USB port detached and cannot be replaced by new parent, Garmin. (See pic)
2. The contacts used for the powered cradle long ago became indented and quit working. I trued a few solutions, none recovered the power connection.
3. From time to time Garmin will make changes that cause Spotwalla to stop working. Jason resolves the problem quickly.
4. Battery life Will decline, as is the case for most little computers
Overall, I am a satisfied user and would buy again.
Sorry about the image quality but this site has limitations in insert-file size.
Great writeup, thanks for the in depth report! I was curious how that "basic weather" would work, and then $1 for more in depth weather? I figured the basic weather wasn't worth much so they would entice you to spend big bucks for the fancy weather, but that basic weather looks pretty good. Except that is for one location, and of course the more important information is what the weather is going to be like in a few hours from now a few hundred miles from where I am now.
DrNeo
Thanks! You can actually use the "Map" function to pull weather from other locations, so you'll know what you're heading into (or not into if you have options ;))
