I downsized to the 2022 Tiger 900. One reason at age 74 my RSV was becoming a beast and getting long in the tooth. Second reason I plan to ride the Trans Labrador Highway this summer so this type of motorcycle would be a better fit. BMW 1250 and Tiger 1200 were out of my price range at present.
I don't like the seat or the chain but I will adapt. The seat has been reworked and I installed a Scott Oiler for the chain. Seems to be working fine.
Now to the point:
My last two motorcycles were carburetor equipped. I had aux fuel tanks on them. They have taken me on many IBA rides, 49 states, and all Canadian provinces/territories with roads. Since both were carburetor equipped, gravity feed worked great. However, I am new to the FI motorcycle world with 2022 emissions requirements.
I have decided to go with my 3 gallon (or maybe the 5 gallon) tank mounted on the pillion. I plan to use the vent hose to feed fuel from the aux to the main as per several of you have done. I understand the fueling process, main first then close, it then fill aux.
My question is since the charcoal canister valve is controlled by the ECU will a code be thrown if I disconnect the vent line on the tank side from the valve to use it for my aux feed? I thought I'd just cap the valve.
For now I am not concerned about the legality of disconnecting the cannister. I can deal with that after I have the aux tank plumbed. One thing at a time.
Now to the point:
