So I was planning on a saddle sore this morning, and doing a hundred mile shakedown yesterday because of recent modifications (I realized my custom pegs were pressing on the brake enough to keep the brake light on at odd moments).
About half a mile from my destination, I hit the rear brake, heard a thunk, felt a kind of hard "kick" in the pedal, and then... no pressure.
I park, look at it, nothing's leaking, nothing looked toooo weird, aside from the brake line looked really tight against the swingarm.
I decide to turn around, ride home and deal with it, hoping to save my vacation.
When I start up the ABS light comes on.
Slightly later, I realize that I no longer have a spedometer. This is not a problem because they are behind me.
I get home, and start looking at it with an eye to the ABS sensor, and realize I cannot conveniently reach the ABS sensor mounting nut because it is behind the pipe.
"This is an odd location", I say
Then I realize the brake is no longer attached to the torque arm. Apparently the bolt/nut attaching it just went away.
It is not loose. Oh, no. It has wrapped about 180' around the wheel and wedged itself against the swingarm, shoving the ABS sensor plate ahead of it (and in fact breaking off its mounting fins), and snapping the ABS sensor electrical connection.... right at the sensor, where I can't solder it.
So I'm out $300 worth of hastily ebayed parts, and a perfectly good vacation plan.
The only good thing is once I got the wheel disassembled and everything unwedged, the brake appears undamaged and pumps up fine.
But eeesh. PSA, go give your brakes a hard once-over.
