Aftermarket Rear Gear for GL1800/F6B?
Has any of the members here see this YouTube video about a guy who is making gear sets for the final drive?
It is supposed to lower RPM's by ~15%. Some of the comments in the video imply a pretty decent uptick in fuel economy (290 miles on 6 gallons of fuel?) and quite a bit of interest.
Comments?
I have not seen that, but it could be a good trade off to avoid adding a fuel cell. If I could average 275 miles per fill up, or even 250, I'd be pretty well pleased compared to the current range. Are you considering trying it out?
Considering it...but the cost of a good fuel cell and other accoutrements to install is roughly the cost of this rear gear.
For what it's worth, I noticed that Henry's own R&D testimonial quotes an MPG figure that isn't that far off from stock. I routinely get in the low 40's at a long, steady-state 60 mph. My experience has been low-mid 40's at 60 mph, and high 30's at 70 mph. (Click on my Fuelly link for verification.)
In my own anecdotal experience (note the qualification), it takes X-amount of horsepower to push a GL1800 through the air at Y-speed. The rpm of the engine doesn't change that fact. Whether you're making that horsepower through spinning fast with a small throttle opening, or spinning slowly with a larger throttle opening, the horsepower needed to push you through the air at Y-speed remains constant.
From where I sit with my own (admittedly) limited understanding of engine design, it seems to me that any mileage gains realized are likely to be from reduced internal friction due to lower engine RPM. Which is fine, but I don't hang my hat on it. There are lots of things that can affect an engine's internal friction besides rear drive ratio.
I'm not for or against the altered rear drive ratio. I'm just saying that I found it interesting that Henry's own site doesn't quote someone who has seen mileage gains.
Draw your own conclusions.
When the gearing was updated, was the speedo recalibrated? If not, a user might just think that they are getting better MPG, when in reality, they are not realizing the gain that is promised.
Most MPG calculations involve ODO/Gallons. But the ODO on most modern vehicles is a calculation of rotations somewhere in the powertrain, and usually before the final drive or tire.
For instance, a 6% higher final drive ratio that nets a 4% calculated improvement in MPG actually cost you 2% if that calculation was not based on an ODO that was calibrated before and after.
That's way too expensive for a 'possible' benefit. Fuel cell is less cost.
Agreed.
I also found it humorous that Henry's site mentioned "reduced engine wear" as one of the benefits. With all the examples of GL1800's with over 300,000 miles on them, it seems like a minimal benefit at best. Keep clean oil in them and the dang things are as close to bulletproof as any motorcycle engine can be.
Plus, I started thinking about the cost of fuel vs. mileage (allegedly) gained vs. ROI, and concluded that you'd have to either recover serious-arse mileage or ride your Gold Wing until Gabriel blows his horn before you'd make up the cost of the new rear drive. And that's just to break even.
Agreed.
And the model isn't even in production anymore. I've been thinking of going a different direction soon. The Goldwing has been the best for two up and comfy iron butts. But I'd like to get something for our local group adv rides and still be able to slab some iron butts here and there. Was thinking super tenere or Africa twin dct. Thoughts?
Given those two options, I'd go for the Super Tenere. Not only am I a big fan of shaft drive for long-distance riding, but the Super Tenere is a pretty darn solid bike. Paul Pelland thrashed the bejeezus out of two of them with nary a whimper. It's still on my short list of Bikes I'd Own If I Didn't Have This Gold Wing.
I am thinking the final drive could be worth it, but not for fuel economy. The first gear seems pointless it's such a quick shift, unless you just redline it like a sport bike which is fun sometimes. I'm thinking the benefit could be from less rider fatigue. With OEM drive, running at 75-85mph the toms are up high and I can feel he vibes through the grip puppies. Cruising at 65 mph feels calm and relaxed. Supposedly the upgrade will keep rpms lower...I believe less than 3k at 70-75mph. If I can keep more relaxed and reduce mental/physical fatigue and still cruise at 75 or so, sounds like it would be worth 1500 bucks.
I'm thinking about picking up a used Henry for the 25 ibr. Has anybody officially tried it?
There was a guy, many years ago, who machined up some FD gears for the 1500c Valkyrie. They fit the GL bikes as well. It was pretty much a fail on the MPG front. It turns out that lowering the RPM at highway speeds does not have a significant effect on MPG. You still have the same coefficient of drag. Mechanical drag might be slightly reduced but the bulk of the coefficient at highway speeds is from air. There's a bunch more engineering in the explanation but suffice to say that there is a lot more to it than 'lowering RPM by 15%'. Another compounding factor is that measuring and reporting MPG is also fairly complicated. It's very hard to get apples to apples numbers.
My records show that I put a 170/80H-15 car tire on the rear of both of my Goldwings. This is taller than both the OEM bike tire and the car tire suggested on the Goldwing forums. I lost 1 MPG (Gallons of fuel per ODO miles) but the speedometer was now accurate at 70 MPH instead of registering 3.5 MPH faster. I did a canned 1035 mile SaddleSore 2 up and my ODO showed about 40 miles less. My brain is only a Z80 at the moment but you should have enough data to figure the differences.
