First solo SS1000 (Armistice) paperwork advice.
ChrisM
Member
Good morning,
I completed my first 'solo' ride on Sunday/Monday, previously I took part in the RBLR1000. I rode the northern clockwise RBLR route and actually made it up to Wick this time.
Anyway, my question is this; is it ok for me to post the ride documentation and then e-mail the start and finish photos? Or do I need to print the photos off?
Thanks in advance for any help.
following on from Chris's post
do you need to scan the receipts or include images of the receipts taken at the time of purchase?
Hi Ian,
Assuming you aren't using witnesses, there are only two mandatory photos: one at the start, showing both start receipt and odo, and one at the end showing finish receipt and odo. Everything else can be done after you've completed the ride: filling out the documentation, scanning (or photographing) all the receipts, and then sending it all to me, via either post or email. A couple of tips: a blob of Blu-tack stuck somewhere near the odo display makes taking the photos easier - stick receipt to Blu-tack and it leaves you with both hands free. Your mileage may vary, especially if it is p***ing down and/or blowing a gale. The other tip is that, while not compulsory (and there's no need to send them in), taking a photo of each receipt with the odo display makes completing the ride log a bit easier.
Regards,
Martin
thanks for the replies, I've good images at the start and finish and most of the way-points are good, the flash bounced off the screen so one or two are a bit washed out, anyway, I'll email over what I've put together and we'll see
i did use the blue tak but some receipts were so long i ended up folding them to make them fit
